Page 2 sur 3 PremièrePremière 123 DernièreDernière
Affichage des résultats 11 à 20 sur 26
Discussion: Comment installer Vbulletin ???
  1. #11
    November 2008
    Par défaut
    encor merci ( jabeli rabi nebda avec le phpBB3 apres sahel ) tnx
    Mon Site (tutos,naruto,prison break....)
    http://amab.p1.fr/
  2. #12
    November 2008
    Par défaut
    re salut xd c bon jai creer un forum phpbb3 doka lazem ntawer chwia lol
    alors voila mon belm ?(sur limage)
    http://amab.p1.fr/
  3. #13
    November 2008
    Par défaut
    vérifie tes ID , Mysql ID et mot de pass dans le ficher Include/Config.php
  4. #14
    November 2008
    Par défaut
    <?php
    || # vBulletin 3.7.3
    || # All PHP code in this file is ©2000-2008 Jelsoft Enterprises Ltd. # ||
    || # This file may not be redistributed in whole or significant part. # ||
    || # ---------------- VBULLETIN IS NOT FREE SOFTWARE ---------------- # ||
    || # http://www.vbulletin.com | http://www.vbulletin.com/license.html # ||
    | ****** NOTE REGARDING THE VARIABLES IN THIS FILE ****** |
    | If you get any errors while attempting to connect to |
    | MySQL, you will need to email your webhost because we |
    | cannot tell you the correct values for the variables |
    | in this file. |
    // ****** DATABASE TYPE ******
    // This is the type of the database server on which your vBulletin database will be located.
    // Valid options are mysql and mysqli, for slave support add _slave. Try to use mysqli if you are using PHP 5 and MySQL 4.1+
    // for slave options just append _slave to your preferred database type.
    $config['Database']['dbtype'] = 'mysql';
    // ****** DATABASE NAME ******
    // This is the name of the database where your vBulletin will be located.
    // This must be created by your webhost.
    $config['Database']['dbname'] = '';
    // ****** TABLE PREFIX ******
    // Prefix that your vBulletin tables have in the database.
    $config['Database']['tableprefix'] = '';
    // ****** TECHNICAL EMAIL ADDRESS ******
    // If any database errors occur, they will be emailed to the address specified here.
    // Leave this blank to not send any emails when there is a database error.
    $config['Database']['technicalemail'] = '';
    // ****** FORCE EMPTY SQL MODE ******
    // New versions of MySQL (4.1+) have introduced some behaviors that are
    // incompatible with vBulletin. Setting this value to "true" disables those
    // behaviors. You only need to modify this value if vBulletin recommends it.
    $config['Database']['force_sql_mode'] = false;
    // ****** MASTER DATABASE SERVER NAME AND PORT ******
    // This is the hostname or IP address and port of the database server.
    // If you are unsure of what to put here, leave the default values.
    $config['MasterServer']['servername'] = 'localhost';
    $config['MasterServer']['port'] = 3306;
    // ****** MASTER DATABASE USERNAME & PASSWORD ******
    // This is the username and password you use to access MySQL.
    // These must be obtained through your webhost.
    $config['MasterServer']['username'] = '';
    $config['MasterServer']['password'] = '';
    // ****** MASTER DATABASE PERSISTENT CONNECTIONS ******
    // This option allows you to turn persistent connections to MySQL on or off.
    // The difference in performance is negligible for all but the largest boards.
    // If you are unsure what this should be, leave it off. (0 = off; 1 = on)
    $config['MasterServer']['usepconnect'] = 0;
    // ****** SLAVE DATABASE CONFIGURATION ******
    // If you have multiple database backends, this is the information for your slave
    // server. If you are not 100% sure you need to fill in this information,
    // do not change any of the values here.
    $config['SlaveServer']['servername'] = '';
    $config['SlaveServer']['port'] = 3306;
    $config['SlaveServer']['username'] = '';
    $config['SlaveServer']['password'] = '';
    $config['SlaveServer']['usepconnect'] = 0;
    // ****** PATH TO ADMIN & MODERATOR CONTROL PANELS ******
    // This setting allows you to change the name of the folders that the admin and
    // moderator control panels reside in. You may wish to do this for security purposes.
    // Please note that if you change the name of the directory here, you will still need
    // to manually change the name of the directory on the server.
    $config['Misc']['admincpdir'] = 'admincp';
    $config['Misc']['modcpdir'] = 'modcp';
    // Prefix that all vBulletin cookies will have
    // Keep this short and only use numbers and letters, i.e. 1-9 and a-Z
    $config['Misc']['cookieprefix'] = 'bb';
    // ******** FULL PATH TO FORUMS DIRECTORY ******
    // On a few systems it may be necessary to input the full path to your forums directory
    // for vBulletin to function normally. You can ignore this setting unless vBulletin
    // tells you to fill this in. Do not include a trailing slash!
    // Example Unix:
    // $config['Misc']['forumpath'] = '/home/users/public_html/forums';
    // Example Win32:
    // $config['Misc']['forumpath'] = 'c:\program files\apache group\apache\htdocs\vb3';
    $config['Misc']['forumpath'] = '';
    // ****** COOKIE SECURITY HASH ******
    // This option allows you to encode cookie.
    // You may use any latin and/or any other alphanumeric symbols.
    // Leave this blank to use the default value.
    // Note: if you change this all users will be logout.
    $config['Misc']['cookie_security_hash'] = '';
    // ****** USERS WITH ADMIN LOG VIEWING PERMISSIONS ******
    // The users specified here will be allowed to view the admin log in the control panel.
    // Users must be specified by *ID number* here. To obtain a user's ID number,
    // view their profile via the control panel. If this is a new installation, leave
    // the first user created will have a user ID of 1. Seperate each userid with a comma.
    $config['SpecialUsers']['canviewadminlog'] = '1';
    // ****** USERS WITH ADMIN LOG PRUNING PERMISSIONS ******
    // The users specified here will be allowed to remove ("prune") entries from the admin
    // log. See the above entry for more information on the format.
    $config['SpecialUsers']['canpruneadminlog'] = '1';
    // ****** USERS WITH QUERY RUNNING PERMISSIONS ******
    // The users specified here will be allowed to run queries from the control panel.
    // See the above entries for more information on the format.
    // Please note that the ability to run queries is quite powerful. You may wish
    // to remove all user IDs from this list for security reasons.
    $config['SpecialUsers']['canrunqueries'] = '';
    // ****** UNDELETABLE / UNALTERABLE USERS ******
    // The users specified here will not be deletable or alterable from the control panel by any users.
    // To specify more than one user, separate userids with commas.
    $config['SpecialUsers']['undeletableusers'] = '';
    // ****** SUPER ADMINISTRATORS ******
    // The users specified below will have permission to access the administrator permissions
    // page, which controls the permissions of other administrators
    $config['SpecialUsers']['superadministrators'] = '1';
    // ****** DATASTORE CACHE CONFIGURATION *****
    // Here you can configure different methods for caching datastore items.
    // vB_Datastore_Filecache - to use includes/datastore/datastore_cache.php
    // vB_Datastore_APC - to use APC
    // vB_Datastore_XCache - to use XCache
    // vB_Datastore_Memcached - to use a Memcache server, more configuration below
    // $config['Datastore']['class'] = 'vB_Datastore_Filecache';
    // ******** DATASTORE PREFIX ******
    // If you are using a PHP Caching system (APC, XCache, eAccelerator) with more
    // than one set of forums installed on your host, you *may* need to use a prefix
    // so that they do not try to use the same variable within the cache.
    // This works in a similar manner to the database table prefix.
    // $config['Datastore']['prefix'] = '';
    // It is also necessary to specify the hostname or IP address and the port the server is listening on
    $config['Datastore']['class'] = 'vB_Datastore_Memcached';
    $i = 0;
    // First Server
    $i++;
    $config['Misc']['memcacheserver'][$i] = '127.0.0.1';
    $config['Misc']['memcacheport'][$i] = 11211;
    $config['Misc']['memcachepersistent'][$i] = true;
    $config['Misc']['memcacheweight'][$i] = 1;
    $config['Misc']['memcachetimeout'][$i] = 1;
    $config['Misc']['memcacheretry_interval'][$i] = 15;
    // ****** The following options are only needed in special cases ******
    // ****** MySQLI OPTIONS *****
    // When using MySQL 4.1+, MySQLi should be used to connect to the database.
    // If you need to set the default connection charset because your database
    // is using a charset other than latin1, you can set the charset here.
    // If you don't set the charset to be the same as your database, you
    // may receive collation errors. Ignore this setting unless you
    // are sure you need to use it.
    // $config['Mysqli']['charset'] = 'utf8';
    // Optionally, PHP can be instructed to set connection parameters by reading from the
    // file named in 'ini_file'. Please use a full path to the file.
    // Example:
    // $config['Mysqli']['ini_file'] = 'c:\program files\MySQL\MySQL Server 4.1\my.ini';
    $config['Mysqli']['ini_file'] = '';
    // Image Processing Options
    // Images that exceed either dimension below will not be resized by vBulletin. If you need to resize larger images, alter these settings.
    $config['Misc']['maxwidth'] = 2592;
    $config['Misc']['maxheight'] = 1944;
    || # CVS: $RCSfile$ - $Revision: 26534 $
    alors ??????? comment en fait ????
    http://amab.p1.fr/
  5. #15
    November 2008
    Par défaut
    je pense que si tu aurai pris 5 minute de ton temps a lire ce qu'il y a dedans tu aurai compris facilement ! je te conseille de lire bien et Configur&#233;
    $config['MasterServer']['servername'] = 'IP address de ton db server';
    $config['MasterServer']['username'] = 'TON USER NAME DE DB';
    $config['MasterServer']['password'] = 'PASSWORD';
    $config['Database']['dbname'] = 'Nom de la db';
    j'ai pas installer des forum vbulletin avant mais a premier vu c'est sa le probl&#232;me .
    par contre c'est bizar que vBulletin on pas un script d'installation o.o
  6. #16
    November 2008
    Par défaut
    euh merci il et enfin installer jai sa
    mais quand je click sur Forum Home Page jai une page bbbiiiiidddaaa http://amabforum.co.cc/VB/upload/index.php
    http://amab.p1.fr/
  7. #17
    January 2008
    Par défaut
    Installe PHPBB3, facile, en français.
  8. #18
    November 2008
    Par défaut
    c bon khdemte bel phpbb3 le VB c plus pro ( z3ma z3ma ) meme c bon fritha 3awte linsalation sa march yyyaaahhhhhhhhhooooooooo
    http://amab.p1.fr/
  9. #19
    November 2008
    Par défaut
    ok ^_^ c cool que tu a r&#233;ussi a l'installer
  10. #20
    November 2008
    Par défaut
    bah hmd ya rebi ki frtitha sadiki tkt mzelni mbasi pask c pas facile comme le phpbb mais khche nahr nkhd3koum be forum kowa xd
    http://amab.p1.fr/
Discussions similaires
  1. [Actualités] Comment installer Android sur un iPhone
    Réponses: 0
    Dernier message: 26/04/2010, 03h00
  2. Need help : Comment installer un .ipa
    Par azraïne dans le forum Iphone
    Réponses: 11
    Dernier message: 05/12/2009, 11h34
  3. [Réglé] Comment installer Ubuntu en MultiBoot
    Par salimdz dans le forum GNU/Linux et Unix
    Réponses: 14
    Dernier message: 01/05/2009, 22h12
  4. comment installer ISA Server.
    Par tigkari dans le forum Cybercafés
    Réponses: 9
    Dernier message: 03/03/2009, 14h37
  5. assila box 2 comment installer la box ,
    Par veniziano dans le forum EEPAD
    Réponses: 9
    Dernier message: 16/09/2008, 20h57
Les tags pour cette discussion
[dlaala.com] [Ennasr] [Annuaire] [Bilan Energetique] [Chauffage] [Musique DZ] [Sur endettements] [Auto utilitaire DZ] [Referencement pagerank] [son2bled.com]
[Mutuelles Santé] [Algérie 360] [Algérie Musique] [Kherdja] [Annuaire EU] [Webimag] [Annuaire 13] [Affacturage] [Devenir proprietaire] [TagBox] [Algérie NEWS] [EXIT TO LIVE] [Dz Vendre] [Algérie Info] [Presse ALgérie]
