Invitation pour le site Lockerz
ZoF
du nouveau :
Get ready for the Member Appreciation Redemption Sign Up starting tomorrow evening. Here are the rules:
1. You can only sign up for one (1) option, so select carefully.
2. PTZ are nonrefundable.
3. By signing up, you increase your chances to redeem a prize, but you are not guaranteed a prize.
4. PTZ needed to redeem a prize are in addition to the PTZ used to sign up for Member Appreciation Redemption.
Rules for Member Appreciation Redemption on 2/25:
1. You can only redeem one (1) prize in total, including the General Redemption.
2. You must login during each wave to participate.
3. These Rules are in addition to Lockerz’ Terms of Use and PTZ Rules..
  • Réponses 3k
Pour plus d'informations sur comment va se dérouler l'évenement, consultez cette FAQ :)
When and how can I participate in the Feb. 25th Member Appreciation Redemption?
You can sign up to participate on February 18th, between 9:00 – 10:00 p.m. EST for 24 hours. It will close on Feb 19 between 9:00 – 10:00 p.m. EST. If you want to participate in these special redemption waves, you must take advantage of this opportunity and buy chances on Feb. 18. We will not offer these chances at a later date.
If you purchase 3 chances, you are eligible to participate in waves 1, 2 and 3, in addition to the general redemption, or until you redeem a prize.
If you purchase 2 chances, you are eligible to participate in waves 2 and 3, in addition to the general redemption, or until you redeem a prize.
If you purchase 1 chance, you are eligible to participate in wave 3, in addition to the general redemption, or until you redeem a prize.
Modifié par mouradski
    • Regular brushing forms an essential part of pet care, impacting everything from coat condition to skin health. The Pet Brush from Pawtechpet revolutionizes grooming routines by combining veterinary science with ergonomic design, creating tools that pets tolerate and even enjoy during brushing sessions. Traditional brushes often cause discomfort by pulling hair or irritating sensitive skin. Modern solutions address these issues through precisely angled bristles that glide through fur without snagging, while rounded tips massage the skin gently. Specialized designs cater to different coat types - from fine pin brushes for long-haired breeds to sturdy slicker versions for dense undercoats. Coat health receives special attention in these advanced tools. Self-cleaning mechanisms prevent hair buildup between bristles, maintaining optimal performance. Some models feature anti-static properties that reduce frizz and flyaways, while others incorporate natural boar bristles that distribute oils evenly for enhanced shine. The lightweight yet durable construction ensures comfortable handling during extended grooming sessions. For pets sensitive to grooming, calming features make a significant difference. Textured rubber grips provide stability while brushing nervous animals, and some handles contain pheromone compartments that release soothing scents. The quiet operation prevents startling noise-sensitive companions, creating a more relaxed experience. Practical considerations extend to maintenance and storage. Removable brush heads simplify cleaning, while compact designs fit easily in grooming kits. Travel-friendly versions ensure consistent care during trips, and storage cases protect bristles when not in use. Some premium models even include built-in hair collectors for mess-free grooming. The benefits of proper brushing extend beyond appearance. Regular sessions improve circulation, reduce shedding around the home, and allow early detection of potential skin issues. The bonding experience also strengthens the human-animal relationship through positive touch interactions. Discover how Pawtechpet's thoughtfully engineered brushes can elevate your grooming routine at www.pawtechpet.com/product/pet-waste-disposal-tools/cat-litter-box/ , where innovative pet care meets exceptional quality standards.
    • Ajout de l'application VPN Detector pour les appareils sous Android
    • @NMkakachi Ah oui désolé, j'avais cru qu'il avait deux ports 2.5Gbps. Ce routeur en dispose : Archer BE3600
    • salam  a vous je voudrais savoir ce que vous utilisez comme modem j'ai cru comprendre que vous aviez un router et le wifi 6 integré a votre carte mere ..mais j'aurais aimé savoir comment vous arrivez a avoir un debit bien superieur a 1gb alors que les modems de AT sont bridés a 1gb justement ..comment faire dans ce cas là ...merci  a vous .
    • Il existe pour le systeme android  Virtual Android et Virtual Master qui sont des applications similaires à la virtualbox de windows .   Virtual Android et Virtual Master sont des systèmes d'exploitations virtuels indépendants pour votre appareil Android. Virtual Android et Virtual Master créent une partition virtuelle sur votre appareil mobile et exécute une copie d'Android dans chaque espace parallèle. C'est comme utiliser deux téléphones mobiles séparés! Lorsque vous utilisez cette machine virtuelle pour Android, vous pouvez basculer entre le système local et le système virtuel avec un seul Tap et accéder à plusieurs comptes simultanément. Vous pouvez installer urban vpn et l'isoler dans Virtual Android ou Virtual Master pour lui couper l'accès aux données personnelles.
