Zving Posted February 20, 2008 Share Posted February 20, 2008 Since defragging the disk won't do much to improve Windows XP performance, here are 23 suggestions that will. Each can enhance the performance and reliability of your customers' PCs. Best of all, most of them will cost you nothing. 1.) To decrease a system's boot time and increase system performance, use the money you save by not buying defragmentation software -- the built-in Windows defragmenter works just fine -- and instead equip the computer with an Ultra-133 or ^^^^^^ ATA hard drive with 8-MB cache buffer. 2.) If a PC has less than 512 MB of RAM, add more memory. This is a relatively inexpensive and easy upgrade that can dramatically improve system performance. 3.) Ensure that Windows XP is utilizing the NTFS file system. If you're not sure, here's how to check: First, double-click the My Computer icon, right-click on the C: Drive, then select Properties. Next, examine the File System type; if it says FAT32, then back-up any important data. Next, click Start, click Run, type CMD, and then click OK. At the prompt, type CONVERT C: /FS:NTFS and press the Enter key. This process may take a while; it's important that the computer be uninterrupted and virus-free. The file system used by the bootable drive will be either FAT32 or NTFS. I highly recommend NTFS for its superior security, reliability, and efficiency with larger disk drives. 4.) Disable file indexing. The indexing service extracts information from documents and other files on the hard drive and creates a "searchable keyword index." As you can imagine, this process can be quite taxing on any system. The idea is that the user can search for a word, phrase, or property inside a document, should they have hundreds or thousands of documents and not know the file name of the document they want. Windows XP's built-in search functionality can still perform these kinds of searches without the Indexing service. It just takes longer. The OS has to open each file at the time of the request to help find what the user is looking for. Most people never need this feature of search. Those who do are typically in a large corporate environment where thousands of documents are located on at least one server. But if you're a typical system builder, most of your clients are small and medium businesses. And if your clients have no need for this search feature, I recommend disabling it. Here's how: First, double-click the My Computer icon. Next, right-click on the C: Drive, then select Properties. Uncheck "Allow Indexing Service to index this disk for fast file searching." Next, apply changes to "C: subfolders and files," and click OK. If a warning or error message appears (such as "Access is denied"), click the Ignore All button. 5.) Update the PC's video and motherboard chipset drivers. Also, update and configure the BIOS. For more information on how to configure your BIOS properly, see this article on my site. 6.) Empty the Windows Prefetch folder every three months or so. Windows XP can "prefetch" portions of data and applications that are used frequently. This makes processes appear to load faster when called upon by the user. That's fine. But over time, the prefetch folder may become overloaded with references to files and applications no longer in use. When that happens, Windows XP is wasting time, and slowing system performance, by pre-loading them. Nothing critical is in this folder, and the entire contents are safe to delete. 7.) Once a month, run a disk cleanup. Here's how: Double-click the My Computer icon. Then right-click on the C: drive and select Properties. Click the Disk Cleanup button -- it's just to the right of the Capacity pie graph -- and delete all temporary files. 8.) In your Device Manager, double-click on the IDE ATA/ATAPI Controllers device, and ensure that DMA is enabled for each drive you have connected to the Primary and Secondary controller. Do this by double-clicking on Primary IDE Channel. Then click the Advanced Settings tab. Ensure the Transfer Mode is set to "DMA if available" for both Device 0 and Device 1. Then repeat this process with the Secondary IDE Channel. 9.) Upgrade the cabling. As hard-drive technology improves, the cabling requirements to achieve these performance boosts have become more stringent. Be sure to use 80-wire Ultra-133 cables on all of your IDE devices with the connectors properly assigned to the matching Master/Slave/Motherboard sockets. A single device must be at the end of the cable; connecting a single drive to the middle connector on a ribbon cable will cause signaling problems. With Ultra DMA hard drives, these signaling problems will prevent the drive from performing at its maximum potential. Also, because these cables inherently support "cable select," the location of each drive on the cable is important. For these reasons, the cable is designed so drive positioning is explicitly clear. 10.) Remove all spyware from the computer. Use free programs such as AdAware by Lavasoft or SpyBot Search & Destroy. Once these programs are installed, be sure to check for and download any updates before starting your search. Anything either program finds can be safely removed. Any free software that requires spyware to run will no longer function once the spyware portion has been removed; if your customer really wants the program even though it contains spyware, simply reinstall it. For more information on removing Spyware visit this Web Pro News page. 11.) Remove any unnecessary programs and/or items from Windows Startup routine using the MSCONFIG utility. Here's how: First, click Start, click Run, type MSCONFIG, and click OK. Click the StartUp tab, then uncheck any items you don't want to start when Windows starts. Unsure what some items are? Visit the WinTasks Process Library. It contains known system processes, applications, as well as spyware references and explanations. Or quickly identify them by searching for the filenames using Google or another Web search engine. 12.) Remove any unnecessary or unused programs from the Add/Remove Programs section of the Control Panel. 13.) Turn off any and all unnecessary animations, and disable active desktop. In fact, for optimal performance, turn off all animations. Windows XP offers many different settings in this area. Here's how to do it: First click on the System icon in the Control Panel. Next, click on the Advanced tab. Select the Settings button located under Performance. Feel free to play around with the options offered here, as nothing you can change will alter the reliability of the computer -- only its responsiveness. 14.) If your customer is an advanced user who is comfortable editing their registry, try some of the performance registry tweaks offered at Tweak XP. 15.) Visit Microsoft's Windows update site regularly, and download all updates labeled Critical. Download any optional updates at your discretion. 16.) Update the customer's anti-virus software on a weekly, even daily, basis. Make sure they have only one anti-virus software package installed. Mixing anti-virus software is a sure way to spell disaster for performance and reliability. 17.) Make sure the customer has fewer than 500 type fonts installed on their computer. The more fonts they have, the slower the system will become. While Windows XP handles fonts much more efficiently than did the previous versions of Windows, too many fonts -- that is, anything over 500 -- will noticeably tax the system. 18.) Do not partition the hard drive. Windows XP's NTFS file system runs more efficiently on one large partition. The data is no safer on a separate partition, and a reformat is never necessary to reinstall an operating system. The same excuses people offer for using partitions apply to using a folder instead. For example, instead of putting all your data on the D: drive, put it in a folder called "D drive." You'll achieve the same organizational benefits that a separate partition offers, but without the degradation in system performance. Also, your free space won't be limited by the size of the partition; instead, it will be limited by the size of the entire hard drive. This means you won't need to resize any partitions, ever. That task can be time-consuming and also can result in lost data. 19.) Check the system's RAM to ensure it is operating properly. I recommend using a free program called MemTest86. The download will make a bootable CD or diskette (your choice), which will run 10 extensive tests on the PC's memory automatically after you boot to the disk you created. Allow all tests to run until at least three passes of the 10 tests are completed. If the program encounters any errors, turn off and unplug the computer, remove a stick of memory (assuming you have more than one), and run the test again. Remember, bad memory cannot be repaired, but only replaced. 20.) If the PC has a CD or DVD recorder, check the drive manufacturer's Web site for updated firmware. In some cases you'll be able to upgrade the recorder to a faster speed. Best of all, it's free. 21.) Disable unnecessary services. Windows XP loads a lot of services that your customer most likely does not need. To determine which services you can disable for your client, visit the Black Viper site for Windows XP configurations. 22.) If you're sick of a single Windows Explorer window crashing and then taking the rest of your OS down with it, then follow this tip: open My Computer, click on Tools, then Folder Options. Now click on the View tab. Scroll down to "Launch folder windows in a separate process," and enable this option. You'll have to reboot your machine for this option to take effect. 23.) At least once a year, open the computer's cases and blow out all the dust and debris. While you're in there, check that all the fans are turning properly. Also inspect the motherboard capacitors for bulging or leaks. For more information on this leaking-capacitor phenomena, you can read numerous articles on my site. Following any of these suggestions should result in noticeable improvements to the performance and reliability of your customers' computers. If you still want to defrag a disk, remember that the main benefit will be to make your data more retrievable in the event of a crashed drive. Quote Link to comment Share on other sites More sharing options...
angie Posted February 20, 2008 Share Posted February 20, 2008 22.) If you're sick of a single Windows Explorer window crashing and then taking the rest of your OS down with it, then follow this tip: open My Computer, click on Tools, then Folder Options. Now click on the View tab. Scroll down to "Launch folder windows in a separate process," and enable this option. You'll have to reboot your machine for this option to take effect. Je m'en souviens encore des crash dus à une application qui flanche et qui bloque le tout!! Ouf,c'est bien fifni ca!!Vista reste à ameliorer grandement!!mais plus ce genre de soucis qui obligent à rebouter a chaque fois Quote Link to comment Share on other sites More sharing options...
didiss Posted February 23, 2008 Share Posted February 23, 2008 good byyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyye Quote Link to comment Share on other sites More sharing options...
didiss Posted February 23, 2008 Share Posted February 23, 2008 copier coller au moins faite la traduction on est francophone pas anglophone Quote Link to comment Share on other sites More sharing options...
Zving Posted February 24, 2008 Author Share Posted February 24, 2008 va apprendre l'anglais sa ne te fera que du bien Quote Link to comment Share on other sites More sharing options...
didiss Posted February 24, 2008 Share Posted February 24, 2008 j4ai Pas Le Temps My Freind Quote Link to comment Share on other sites More sharing options...
didiss Posted February 24, 2008 Share Posted February 24, 2008 voila cousin j'ai tout appris . Depuis defragging le disque won't font beaucoup pour améliorer l'exécution de Windows.xp, voici 23 suggestions qui . Chacun peut augmenter l'exécution et la fiabilité de votre customers' ; PCS Mieux de tous, la plupart d'entre elles ne vous coûtera rien. 1.) pour diminuer un temps d'initialisation de system's et augmenter l'exécution de système, employez l'argent vous économiser par ne pas acheter le logiciel de defragmentation -- l'amende de travaux de defragmenter de Windows de fonction intégrée juste -- et équipez à la place l'ordinateur d'un Ultra-133 ou la commande dure d'ATA de ^^^^^^ de l'antémémoire 8-MB. 2.) si un PC a moins le mb de 512 de RAM, ajoutez plus de mémoire. C'est une mise à niveau relativement peu coûteuse et facile qui peut spectaculairement améliorer l'exécution de système. 3.) s'assurent que Windows.xp utilise le système de fichiers de NTFS. Si you're non sûr, here's comment vérifier : D'abord, double-clic la mon icône d'ordinateur, right-clic sur le C : Conduisez, puis les propriétés choisies. Après, examinez le type de système de fichiers ; s'il indique FAT32, alors soutenez n'importe quelles données importantes. Après, le début de clic, course de clic, le type CMD, et cliquent alors BIEN. Au message de sollicitation, dactylographiez le CONVERTI C : /FS:NTFS et appuient sur la touche de pénétrer dans. Ce processus peut prendre un moment ; it's important que l'ordinateur soit non interrompu et virus-libre. Le système de fichiers employé par la commande amorçable sera FAT32 ou NTFS. Je recommande fortement NTFS pour sa sécurité, sérieux, et efficacité supérieurs avec de plus grandes unités de disques. 4.) neutralisent l'indexation de dossier. Le service d'indexation extrait l'information à partir des documents et d'autres dossiers sur la commande dure et crée un mot-clé "searchable index." ; Comme vous pouvez imaginer, ce processus peut tout à fait imposer sur n'importe quel système. L'idée est que l'utilisateur peut rechercher un mot, une expression, ou une propriété à l'intérieur d'un document, devrait ils avoir des centaines ou des milliers de documents et ne pas savoir le nom de fichier du document qu'ils veulent. La fonctionnalité intégrée de recherche de Windows XP's peut immobile exécuter ces genres de recherches sans service d'indexation. Il prises justes plus longues. L'OS doit ouvrir chaque dossier à l'heure de la demande d'aider à trouver ce que l'utilisateur recherche. La plupart des personnes n'ont jamais besoin de ce dispositif de recherche. Ceux qui sont typiquement dans un grand environnement de corporation où des milliers de documents sont localisés sur au moins un serveur. Mais si you're un constructeur typique de système, la plupart de vos clients sont de petites et moyennes entreprises. Et si vos clients n'ont aucun besoin de ce dispositif de recherche, je recommande de le neutraliser. Here's comment : D'abord, double-clic la mon icône d'ordinateur. Après, right-clic sur le C : Conduisez, puis les propriétés choisies. Service d'indexation de "Allow d'Uncheck pour classer ce disque pour le dossier rapide searching." ; Après, appliquez les changements au "C : subfolders et dossiers, " ; et OK de clic. Si un message d'avertissement ou d'erreur apparaît (comme des "Access est le denied" , cliquez l'ignorer tout le bouton. 5.) mettent à jour les conducteurs de jeu de puces de vidéo et de carte mère de PC's. En outre, la mise à jour et configurent le BIOS. Pour plus d'information sur la façon dont configurer votre BIOS correctement, voir le cet article sur mon emplacement. 6.) vident la chemise de Windows Prefetch tous les trois mois ou ainsi. "prefetch" de bidon de Windows.xp ; parties de données et d'applications qui sont employées fréquemment. Ceci fait des processus sembler charger plus rapidement une fois invité par l'utilisateur. That's très bien. Mais temps d'excédent, la chemise de prefetch peut devenir non surchargée avec des références aux dossiers et des applications plus en service. Quand cela se produit, Windows.xp perd le temps, et ralentit l'exécution de système, en les préchargeant. Rien critique n'est dans cette chemise, et il est sûr supprimer le contenu entier. 7.) une fois par mois, courent un nettoyage de disque. Here's comment : Double-clic la mon icône d'ordinateur. Puis right-clic sur le C : conduisez et choisissez les propriétés. Cliquez le bouton de nettoyage de disque -- it's juste à la droite du graphique de pâté en croûte de capacité -- et supprimez tous les fichiers temporaires. 8.) dans votre directeur de dispositif, double-clic sur le dispositif de contrôleurs d'ide ATA, et s'assurent que DMA est permis pour chaque commande que vous vous êtes reliée au contrôleur primaire et secondaire. Faites ceci par double-cliquer sur la Manche primaire d'ide. Cliquez alors l'étiquette avançée d'arrangements. Assurez le mode de transfert est placé au "DMA si available" ; pour le dispositif 0 et le dispositif 1. Répétez alors ce processus avec la Manche secondaire d'ide. 9.) améliorent le câblage. Comme dur-conduisent la technologie s'améliore, les conditions de câblage de réaliser ces poussées d'exécution sont devenues plus rigoureuse. Soyez sûr d'employer des câbles de 80-wire Ultra-133 sur tous vos dispositifs d'ide avec les connecteurs correctement assignés aux douilles assorties de Master/slave/Motherboard. Un dispositif simple doit être à l'extrémité du câble ; relier une commande simple au connecteur moyen sur un câble plat causera signaler des problèmes. Avec ultra les commandes dures de DMA, ces problèmes de signalisation empêcheront la commande de l'exécution à son potentiel maximum. En outre, parce que ces câbles soutiennent en soi "cable choisissez, " ; l'endroit de chaque commande sur le câble est important. Pour ces raisons, le câble est conçu ainsi le positionnement d'entraînement est explicitement clair. 10.) enlèvent tout le spyware à partir de l'ordinateur. Programmes libres d'utilisation tels qu'adAware par Lavasoft ou & de recherche de SpyBot ; Détruisez. Une fois que ces programmes sont installés, soyez sûr de vérifier et de télécharger toutes les mises à jour avant de commencer votre recherche. Quelque chose l'une ou l'autre trouvailles de programme peut être sans risque enlevé. N'importe quel logiciel libre qui exige du spyware de fonctionner ne fonctionnera plus une fois la partie de spyware a été enlevé ; si votre client veut vraiment le programme quoiqu'il contienne le spyware, réinstallez-simplement le. Pour plus d'information sur Spyware d'enlèvement visitez cette pro page de nouvelles de Web. 11.) enlèvent tous les programmes et/ou articles inutiles de la routine de démarrage de Windows en utilisant l'utilité de MSCONFIG. Here's comment : D'abord, début de clic, course de clic, type MSCONFIG, et OK de clic. Cliquez l'étiquette, puis l'uncheck de démarrage tous les articles que vous don't veulent commencer quand Windows commence. Incertain ce qui sont quelques articles ? Visitez la bibliothèque de processus de WinTasks. Elle contient des processus connus de système, applications, aussi bien que des références de spyware et des explications. Ou identifiez-rapidement les en recherchant les noms de fichier en utilisant un Google ou un Search Engine différent de Web. 12.) enlèvent tous les programmes inutiles ou inutilisés de la section de programmes d'Add/Remove du panneau de commande. 13.) en arrêtent et toutes les animations inutiles, et neutralisent le dessus de bureau actif. En fait, pour l'exécution optimale, arrêtez toutes les animations. Windows.xp offre beaucoup de différents arrangements dans ce secteur. Here's comment à faites-le : Premier clic sur l'icône de système dans le panneau de commande. Après, clic sur l'étiquette avançée. Choisissez le bouton d'arrangements situé sous l'exécution. Sentez-vous libre pour jouer autour avec les options offertes ici, car rien que vous pouvez changer ne changera la fiabilité de l'ordinateur -- seulement sa réponse. 14.) si votre client est un utilisateur avançé qui est confortable éditant leur enregistrement, essayent certains des coups secs d'enregistrement d'exécution offerts au coup sec XP. 15.) visitent l'emplacement de mise à jour de Microsoft Windows régulièrement, et téléchargent toutes les mises à jour marquées critiques. Téléchargez toutes les mises à jour facultatives à votre discrétion. 16.) mettent à jour le logiciel d'anti-virus de customer's sur un hebdomadaire, même quotidien, base. Assurez-vous qu'ils font installer seulement un progiciel d'anti-virus. Le logiciel de mélange d'anti-virus est une manière sûre d'orthographier le désastre pour l'exécution et la fiabilité. 17.) s'assurent que le client a moins de 500 le type polices installées sur leur ordinateur. Plus qu'ils ont polices, plus lent le système deviendra. Tandis que Windows.xp manipule des polices beaucoup plus efficacement que les versions précédentes de Windows, trop de polices -- c'est-à-dire, quelque chose plus de 500 -- imposeront sensiblement le système. 18.) ne divisent pas la commande dure. Le système de fichiers de Windows XP's NTFS fonctionne plus efficacement sur une grande cloison. Les données ne sont pas plus sûres sur une cloison séparée, et une restructuration n'est jamais nécessaire pour réinstaller un logiciel d'exploitation. La même offre de personnes d'excuses pour l'usage des cloisons s'appliquent à employer une chemise à la place. Par exemple, au lieu de mettre toutes vos données sur le D : conduisez, mis lui dans une chemise appelée le "D drive." ; You'll réalisent les mêmes avantages d'organisation qu'une cloison séparée offre, mais sans dégradation dans l'exécution de système. En outre, votre espace libre won't soit limité par la taille de la cloison ; au lieu de cela, il sera limité par la taille de la commande dure entière. Ceci vous signifie le besoin de won't de remettre à la côte toutes les cloisons, jamais. Que chargez peuvent prendre du temps et peuvent également avoir comme conséquence des données perdues. 19.) vérifient la RAM de system's pour l'assurer fonctionne correctement. Je recommande d'employer un programme libre appelé MemTest86. Le téléchargement fera un CD ou une disquette amorçable (votre choix), qui exécuteront 10 essais étendus sur la mémoire de PC's automatiquement après que vous initialisiez au disque que vous avez créé. Permettez à tous les essais de courir jusqu'à ce qu'au moins trois passages des 10 essais soient accomplis. Si le programme rencontre n'importe quelles erreurs, arrêtez et débranchez l'ordinateur, enlèvent un bâton de la mémoire (vous assumant ayez plus d'un), et exécutent l'essai encore. Rappelez-vous, mauvaise mémoire ne peut pas être réparé, mais être seulement remplacé. 20.) si le PC a un enregistreur de CD ou de DVD, examinent l'emplacement de Web du lecteur manufacturer's pour assurer les progiciels mis à jour. Dans certains cas you'll puisse améliorer l'enregistreur à une vitesse plus rapide. Mieux de tous, it's librement. 21.) neutralisent des services inutiles. Windows.xp charge beaucoup de services des lesquels votre client très probablement n'a pas besoin. Pour déterminer quels services vous pouvez neutraliser pour votre client, visitez l'emplacement noir de vipère pour des configurations de Windows.xp. 22.) si le malade de you're d'une fenêtre simple d'explorateur de Windows se brisant et prenant alors le reste de votre OS vers le bas avec lui, suivent alors ce bout : ouvrez mon ordinateur, clic sur des outils, puis options de chemise. Cliquez maintenant sur l'étiquette de vue. Faites défiler vers le bas aux fenêtres de chemise de "Launch dans un processus séparé, " ; et permettez cette option. You'll doivent recharger votre machine pour que cette option entre en vigueur. 23.) au moins une fois par an, ouvrez le comput Quote Link to comment Share on other sites More sharing options...
Zving Posted February 24, 2008 Author Share Posted February 24, 2008 quand on veut on peut !! c deja au moins sa d'appris : traduire les text, next step : comprendre directement si ta le temps biensur mais c pas obligatoire vu kil ya google biensur. jespere que les 23 trucs ont servis. salam Quote Link to comment Share on other sites More sharing options...
