Configuration Entrée de gamme 35000da max
Deviil-Boy
CPU ECS_buttom_03.gif LGA775 socket for latest Intel® Core™ 2 Quad / Core™ 2 Duo / Pentium 4 / Celeron D processorECS_buttom_03.gif FSB 1066/800/533 MHzECS_buttom_03.gif Support Hyper-Threading Technology
CHIPSET ECS_buttom_03.gif VIA® P4M900CD & VT8237SECS_buttom_03.gif North Bridge: VIA® P4M900CDECS_buttom_03.gif South Bridge: VIA® VT8237S
GRAPHICS ECS_buttom_03.gif Integrated Chrome9™ HC IGPECS_buttom_03.gif Share Memory: Maximum up to 256MB
MEMORY ECS_buttom_03.gif Single-channel DDR2 memory architectureECS_buttom_03.gif 2 x 240-pin DDR2 DIMM socket support up to 4 GBECS_buttom_03.gif Support DDR2 667/533/400 DDR2 SDRAM
EXPANSION SLOT ECS_buttom_03.gif 1 x PCI Express x16 slotECS_buttom_03.gif 1 x PCI Express x1 slotECS_buttom_03.gif 2 x PCI slots
STORAGE ECS_buttom_03.gif Support by VIA® VT8237S ECS_buttom_06.gif2 x Ultra DMA133/100/66 devices ECS_buttom_06.gif2 x ****** ATAII 3.0Gb/s devices ECS_buttom_06.gifRAID0 & RAID1 configuration
AUDIO ECS_buttom_03.gif VIA® VT1708A 6-channel High Definition audio CODEC
LAN ECS_buttom_03.gif VIA® VT6103L 10/100 Mbps Fast Ethernet PHY
REAR PANEL I/O ECS_buttom_03.gif 1 x PS/2 keyboard & PS/2 mouse connectorsECS_buttom_03.gif 1 x ****** port (COM1)ECS_buttom_03.gif 1 x VGA portECS_buttom_03.gif 4 x USB portsECS_buttom_03.gif 1 x RJ45 LAN connectorECS_buttom_03.gif 1 x Parallel port (LPT1) (Optional)ECS_buttom_03.gif 1 x Audio port (Line-in, Line-out, Mic-in)
INTERNAL I/O CONNECTORS & HEADERS ECS_buttom_03.gif 1 x 24-pin ATX Power Supply connectorECS_buttom_03.gif 1 x 4-pin ATX 12V connectorECS_buttom_03.gif 1 x FDD connectorECS_buttom_03.gif 1 x IDE connectorECS_buttom_03.gif 2 x ****** ATA connectorsECS_buttom_03.gif 2 x USB 2.0 headers support additional 4 USB PortsECS_buttom_03.gif 1 x IrDA for SIR headerECS_buttom_03.gif 1 x SPDIF out headerECS_buttom_03.gif 1 x Clear CMOS headerECS_buttom_03.gif 1 x Front panel switch/LED headerECS_buttom_03.gif 1 x Front panel audio headerECS_buttom_03.gif 1 x CD in headerECS_buttom_03.gif CPUFAN/SYSFAN connectors
SYSTEM BIOS ECS_buttom_03.gif AMI BIOS with 4Mb Flash ROMECS_buttom_03.gif Supports Plug and Play 1.0A, APM 1.2, Multi Boot, DMIECS_buttom_03.gif Supports ACPI revision 1.0 specification
FORM FACTOR ECS_buttom_03.gif Micro-ATX Size, 244mm*200mm
humm pr 3million 5 j;
dual core 3ghz 7000DA
carte mere gigabyte entré de game 7000da
geforce 8500GT 6500da
2go de ram DDR2 je croi que c 3500da je me rappel pas si c lé 600mhZ ou 800Mhz
dique dure SATA 160go 5000da
ecran CRT 17pouce 6500da
oups ca depasse un peu 3million 750 Da sans boitié ^^
mais tu peux joué a CoD4 :)
Merci makubex mais ou mon ami pourais avoir cette config?
