Invitation pour le site Lockerz
ZoF
  • Réponses 3k
Very important redemption update: Our mistake! PTZ levels were incorrect (too high) on today's redemption, due to an error on our part. A few announcements:
1) We will have another redemption tomorrow at the CORRECT PTZ levels. If you failed to redeem or if you redeemed a wallpaper in today's redemption, you are eligible to participate in tomorrow's redemption.
2) If you redeemed today, we will promptly refund the difference between the correct PTZ levels and today's PTZ levels to your account. We then will resume the normal processing of today's redemption.
We are so sorry for any confusion or upset this may have caused – thanks for giving us the chance to make it right:-)
donc y aura une redeem ce soir
  • 4 weeks later...
Sa fait un bail sa veux dire quoi sa :s
PTZ Expiration Update: As you know, PTZ expire a year from the month in which you earn them. However, since CONNECT and 24/7 redemption will launch soon, we want to give you the chance to put your PTZ to work for you. Therefore, we won't start to expire ANY PTZ until after these two features have launched (hint---it's REALLY soon:-)).9 hours, 58 minutes ago
Sa marche toujours ce truc !!, parce que je ne crois toujours pas mes yeux, si oui j'ai besoin d'une invitation en urgence :D !!.
question ?
dois je mettre tous les information personnelle (nom, prénom, age.....) pour que sa marche ou l'adresse seule suffit !! merci de m'aider .
Modifié par gothi
    • Every memorable gathering benefits from thoughtful details, and adding Party Printed Paper Napkins to your décor instantly elevates the ambiance. Quality Party Printed Paper Napkins not only serve practical purposes but also act as miniature art pieces that tie together your event’s theme. From vibrant birthday celebrations to elegant bridal showers, these napkins bridge functionality and festivity in one simple touch. 1. Vibrant Design Selection Choosing the right pattern is the first step. Modern printing techniques offer rich, fade‑resistant inks in an array of colors and motifs—floral, geometric, or even personalized monograms. Mix and match styles to coordinate with table linens, centerpieces, and overall color schemes for a cohesive visual statement. 2. Eco‑Friendly Material Choices Sustainable celebrations are on the rise. Many napkins now feature 100% recycled paper or responsibly sourced fibers, combined with biodegradable inks. These eco‑friendly options deliver the same softness and strength you expect while reducing environmental impact and demonstrating your commitment to green practices. 3. Theme‑Driven Party Planning Whether hosting a tropical luau, a retro 80s bash, or a whimsical baby shower, napkin designs can reinforce your chosen theme. Consider patterns with palm leaves for summer soirées or confetti prints for milestone birthdays. Using coordinated napkins helps guests immerse themselves in the festive atmosphere from the moment they sit down. 4. Papernapkinfactory Custom Solutions For truly unique gatherings, explore custom printing services. papernapkinfactory allows you to upload logos, event dates, or bespoke artwork. These personalized napkins become keepsakes that guests can take home, ensuring your celebration lingers in memories long after the last slice of cake is gone. 5. Storage and Care Tips To maintain print clarity and prevent creasing, store napkins flat in a cool, dry place away from direct sunlight. If outdoor events are on the agenda, include decorative napkin holders or weighted napkin rings to keep them from blowing away. Proper storage also ensures crisp presentation when it’s time to entertain again.Thoughtful choices in napkin design and quality can transform any event into an unforgettable experience. For more exquisite selections and detailed product information, visit www.papernapkinfactory.com/product/
    • In today’s high-demand industrial settings, a reliable Industrial Plug Socket Connector is essential to maintain uninterrupted operations and safeguard critical machinery. The integration of an Industrial Plug Socket Connector into your power distribution network not only reduces downtime from loose connections but also enhances overall energy efficiency. By selecting components engineered for rugged environments, facilities can minimize maintenance costs and achieve consistent performance under heavy loads. 1. Evolution of Power Interfaces From simple two-pin plugs to sophisticated multi-contact connectors, power interfaces have evolved to meet the growing complexity of industrial applications. Early designs focused on basic conductivity, whereas modern solutions prioritize sealing, quick coupling, and ergonomic handling to accelerate installation and reduce human error. 2. Key Specifications to Consider When choosing a connector, evaluate current rating, voltage class, and ingress protection (IP) level. High-current operations often require contacts rated above 63 A, while outdoor installations demand IP67 or higher. Cable gland compatibility and temperature tolerance—often between –25 °C and +85 °C—should also align with your operational environment. 3. nante Modular Design Advantages The team at nante has developed modular socket assemblies that allow rapid customization. By snapping in additional modules—such as signal ports or Ethernet interfaces—engineers can adapt existing panels for new equipment without rewiring the entire system. This plug-and-play flexibility accelerates deployment in expanding production lines. 4. Ensuring Safety and Compliance Industrial connectors must comply with international standards like IEC 60309 and UL 1686. Look for features such as shuttered contacts to prevent accidental touch, reinforced cable grips to avoid strain-related failures, and flame-retardant housings to withstand arc faults. Certified components provide peace of mind and simplify regulatory inspections. 5. Predictive Maintenance and Lifespan Advanced connectors can integrate with sensors to monitor parameters like contact resistance and temperature rise. Predictive analytics platforms ingest this data to forecast potential failures, scheduling proactive replacements before disruptions occur. A well-implemented maintenance regime can extend connector lifespan beyond 100 000 mating cycles. Selecting the right connector architecture is a strategic investment in productivity and safety. For complete technical details and ordering information, visit https://www.nante.com/product/
    • en effet...mais c'est l'algerie...en plus tu pourrai attendre des mois pour l'activation...si t'es chanceux ca sera juste 1 mois...sinon ca peut aller jusqu'a 3...!
    • Ceci est un contenu masqué, merci de Se connecter ou S’inscrire
