Comment configurer Sagem 3302 avec Anis sans modifier le Firmware original!
OuahabiXII
Salam à tous, mon ancien compte est supprimé ou désactivé, en tout cas j'arrive pas a logger et j'était obligé de m'inscrire à nouveau, laissez nous debuter:
P.S:
Je suis Anglophone donc ne me judge pas par mon Français :D
Mon Article Originale
Configuration du Sagem F@ast 3302 avec service Anis sans modifier le Firmware!
So you may noticed that I was offline because of the latest crisis between EEPAD and AT that made us a legitimate collateral victims in their conflict if we can say, that’s Algeria, welcome to the World of “Haraymiyah” or “Narnia”, it depends, let’s get back to our topic.
This isn’t a tough task as most of the guys think, or as has been published on so many Algerian and other forums, that the only way to do so you have to change your Sagem firmware!
No, not any more with me, I’ll explain how you can do it the easy and simple way.
As they said, the need is the mother of the invention, and after the latest EEPAD blackout I found myself subscribing again for another phone line just in case EEPAD came back again, and I’ve subscribed for an Anis connection, and here I am with my Sagem 3302 modems looking for a way to set them up so they’ll work with this new ISP configuration, sorry but the old technique of changing the firmware didn’t work for me and the others who have the latest firmware version, anyway I didn’t like to change my old EEPAD interface, so let’s start!
1- Open a Telnet terminal by entering the console mode in Linux or DOS (CMD) in Windows and type : telnet (then hit enter of course)
You’ll get prompted to a telnet shell that will look like this (telnet>) or this (Microsoft Telnet>)
2- Open a connection to your modem using this command:
Telnet>open 192.168.30.1
3- You’ll be asked to enter your logging username/password accordingly, by default you can use the support logs:
USERNAME: support
PASSWORD: 33P4dM1H
4- Now you’re in, you need to access the suitable service, so just type this in the new prompt:
[support @ home]$atm
5- the home will be changed to atm, if so then you’re ok, now add ANIS VPI/VCI like this:
[support @ atm]$vcadd 8 35 ubr aal5 -o -peak 3000 -avg 3000
(it should give you nothing, if so then you’re still ok)
6- Nice, it’s done, now we need to save our new entry, and to do that we need to get back to our home dir, just type (..):
[support @ atm]$..
(it should become again like this [support @ home]$)
7- Save your setting by typing the (save) command:
[support @ home]$save
8- Now you have to get back to your browser and open your Router interface there:
http://support:33P4dM1H@192.168.30.1
9- Go to the WAN Configuration (Configuration WAN) and click on your previous EEPAD pre-set conf and change your VPI/VCI values to 8/35, enter your username/password and the main thing don’t forget to change the Authentification to CHAP, that’s it and you should be logged in as I am now, here is a screen shot (it’s resized to fit in but you can open it in it’s orig size):
By
ABOUBAKR SEDDIK OUAHABI
OuahabiX
Traduction:
1- Ouvrir un terminal Telnet par le Mode Console sous Linux ou par DOS (CMD) sous Windows et taper : telnet (puis appuyer sur entrer)
Normalement vous devez avoir une Prompt de Telnet du genre de (telnet>) ou bien (Microsoft Telnet>)
2- Ouvrir une connection a votre modem par la commande suivante:
3- Il te demande de remplir vos username/password successivement, tu peux utiliser les logs par défaut du support qui sont bien connus ici:
USERNAME: support
PASSWORD: 33P4dM1H
4- Maintenant vous etes logger, tu dois accéderer le bon service, donc il te faut juste de taper a votre nouvelle prompt:
5- Le répertoir home se changera à atm, si c'est le cas donc tu es dans le bon chemin, maintenant ajouter les paramètres ANIS VPI/VCI comme ça:
(elle suppose de retourner rien pour une étape ideal free des erreurs)
6- Bon, c'est fini, maintenant nous voulons sauvegarder ce que en a fait dernièrement, et pour faire ça il faut qu'on descend au répertoir mére a nouveau (home), donc en tape (..):
[support @ atm]$..
(La racine doit etre retourner support @ home]$)
7- Sauvegarder votre modification par la commande (save):
8- Retourner chez votre navigateur Web et ouvris votre interface du router:
9- Allez chez la Configuration WAN et cliquer sur l'ancienne configuration d'EEPAD et changer les valeurs du VPI/VCI vers 8/35, entrer votre username/password et surtout n'oublier pas de changer l' Authentification vers CHAP, c'est tout et normalment tu dois etre connecté après ça comme moi, screen shot:
Par
OuahabiX
P.S:
N'oublier pas de sauvegarder a nouveau les changements récents.
Modifié par OuahabiXII
N'oublier pas de sauvegarder a la fin!
  • Réponses 63
moi j'ai été obligé de flasher le 3302! car meme avec le changement des vpi/vci il ne fonctionné pas, il se sinchronisé et c'est tout, donc j'ai remis le firm d'alice, la pas de problème sauf que les voyants sur le 3302 sont tous décalés :) si quelcun a testé la méthode de ouahabi??? si ca fonctionne je reflash avec le firm d'eepad pour retrouver les voyants à leurs place :) merci
Et qq chose d'autre, après l'application du méthode, cliquer sur la conf d'EEPAD (la 0/35) sur la même page du Configuration WAN et arrête la avec la bouton Arrêter, et puis Démarrer le service Anisien (8/35), pour savoir s'il est bien configurer tu dois voir le service d'EEPAD en état (Inactive) en rouge comme l'image du screenshot et l'autre service d'Anis en (négociation) puis (Active) en vert, si non le modem va essayer de connecter avec les anciens paramètres.
j'ai une connexion fawri et ca ne marche pas avec le modem f@st 800,j'ai réinstaller le modem usb à plusiere reprise en méttant 0/38 (fawri) et ca ne marche toujours pas,la j'ai téléchargé la derniere version du pilote du modem j'éspere que ca marchera avec.
justement j'aimerais bien savoir comment configurer les modems suivant, car ce n'est pas juste une histoire de changement des paramètres vpi/vci j'imagine:
sagem f@st 800
sagem f@st 800/840
salam...j'ai essayer ta methode pour anis adsl..mais j'arriv pa a entrer mon mot de pass...quand j ecris support ...rien ne s'ecris ..et kan j appuy sur etréé..il revien a login...sauf kan j 'ecri user /user ...mais pour l'etape suivante ...quan j ecris atm ..il me di COMMAND NOT FOUND..et c la meme choz quan jutiliz le ******** avec ftp ..jarriv pa a entrer mon mot de pass root...aidez moi pls
sagem f@st 800
sagem f@st 800/840
c tres facile quand tu installe avec le cd tu n'as q choisir
0.35 pour easy
8.35 pour anis
0.38 pour fawri
donc c'est juste une question d'installation puis choisir les paramètres vpi/vci adéquats, et puis y a rien d'autres à faire ?
Oui, le F@st 800 et plus simple que la série 3302, il te suffit de mettre les bons paramètres au temps du première installation comme Gladiateur la dit.
Si la commande SAVE ne marche pas chez vous, tu peux utiliser l'interface Web pour sauvegarder les modifications.
Glad pas Wef, sorry
Merci pour le tuto :) j'épingle ton sujet.
Si quelqu'un pouvez confirmer que ce tuto fonctionne correctement sa serait parfait :)!!
mais ,je veux procéder par le CD est ce que ça me suffira juste de changer les paramètres vpi/vci ? pour que ça soit compatible avec fawri, anis , car pour easy c'est pareil de ce côté la avec eepad
c'est quoi ça ! sauvegarder!!
C'est pour les Sagems 3302 seulement, si vous n'enregistrez pas les nouvelles modifications, tout les paramètres seront perdus à la prochain Reboot, c'est pour ça qu'on est obligé de sauvegarder (enregistrer) les modifications chaque fois qu'on change qq chose.
Si tu as un F@st 800 tu n'aura pas demander de faire ça.
ah d'accord, sinon pour le f@st 800/840 , j'an ai juste à modifier les paramètres vpi/vci! merci!
